Brilhante Alex!!! Esse artigo não conhecia, e de facto desses já tive no meu uns 4/5 problemas, mas nada que não se resolvesse facilmente.
Já agora, para enriquecer um pouco mais este tópico, deixo aqui uma lista dos problemas comuns do X300:
*1 Cracks in exhaust manifold
*2 Faint LCD clock display segments
3 Leaking automatic dimming rear view mirror– Free replacement
(Improved model)
4 Oil pressure sender fails–Early models only
5 Seat memory (small changes?) & stiff front-to-back movement switch
*6 Fuel sender shows 3/4 full when tank full– Clean or renew
sender
7 Rust spots along windscreen rubber area- Visual check
8 Failed steering wheel motor, either the up/down (tilt) or in/out
-Drive coupling shaft fails
9 Leaking camshaft cover seal-Chk the front of the head for oil
leaks– Renew seal
*10 Cylinder head gasket – Slight oil loss near oil galley–Renew
with imprvd vers
11 Front lower wishbone bushes worn-Renew
12 Split on front downpipe– Re-weld
13 Rust on rear wheel arches (pre ‘95 modls)
14 Radio fails to recognize CD player (NOT CONT)– (re)solder SMD
component
15 Rough idle– Use correct spark plugs
*16 Dirty throttle body –Leads to stiff throttle/rough idle –Clean
*17 Corroding rear bumper supports -Renew
*18 Moldy smell when A.C. is switched on or off –Clean
evaporator
19 Timing chain rattle– Fit new-style tensioner
*20 Worn front shock absorber isolators cause clunking noises in
car front- Renew
*21 Worn lower radiator mounting bushes- Renew
22 Leaking power steering high-pressure hose– Renew every 100k
23 Gas tank takes ages to completely fill– Clean pipe to charcoal
canister
*24 Failed J-gate lighting– Renew bulb or use a green 12V LED
25 Premium sound rear woofer cone detaching from voice coil
* 26 Sagging headliner (hot climates only)- Renew
27 Cable(s) through boot lid hinge can fracture
28 Worn driver’s seat bolsters
*29 Corroded valve cover
30 Loose flex (Jurid) driveshaft fitting– Tighten
31 Broken fins on rear centre-vent
32 Bad brake/park microswitch– Adjust
33 Heater pump fails– Renew brushes (Brushes NOT available from
Jaguar)
34 Interior lights flicker– Clean or renew rear door microswitch
*35 Boot lock barrel seizes– Clean & lubricate (Graphite powder) -
USE REGULARLY TO AVOID PROBLEM
36 Worn A-frame bushes cause knocking noises from rear of car– Renew
37 Supercharger pulley bearing fails– Renew
38 Dash lights fail/intermittent – Renew/repair ECU in steering
column
*39 Bowden cable to open driver’s door fails– Renew or repair
*40 Dull/misty headlamps– Clean INSIDE of glasses using
polishing compound
41 Cracked seat frame– Weld together
42 Leaking oil bypass O-rings- Renew
43 Leaking CPS O-ring- Renew
44 Loose upper steering column
45 Loose front undertray
46 Play in driver’s seat tracks
47 Corroded bulkhead post terminal
48 High level brake light comes unstuck– Re-glue
49 Bonnet insulation rubbing on valve cover
50 Door stay breaks away from door
51 Crankshaft position sensor fails
Outra parte que me diz muito, são as lavagens. Em relação às lavagens automáticas, é bem verdade, são terríveis para os nosso carros. Para terem uma ideia, este era o estado do meu menino quando o comprei há uns 4/5 anos, que esteve 10 anos a ser lavado em rolos e lavagens mal feitas. Ainda por cima as pinturas originais dos Jags são muito delicadas:
Já agora na fase de polimento:
E depois.
